Sonnar Brian
That is true. I moved the entire focus mount out so that it would be exact for 8ft. That way, the Sonnar could be used effectively wide-open and close-up. The Sonnar focus shift that occurs with stopping down then helps improve focus at infinity.
I also just looked at my Contax IIIa and Nikon S and S2.
The Contax Helical rotates 270 degrees when moving from 3ft to infinity.
The Nikon S moves less, about 260 degrees. So both mounts can use the same pitch, and the Nikon lens is moved less distance from the film plane while focussing.
