To answer the questions :
cam : if you send me the lenses, I will add the frames ๐. Yet I think that except for the 12mm, you can extrapolate with a polynomial function ๐ and draw them
Yes, Tahiti and the other Polynomial Islands have inspired many artists and have been the site of happy soirees and functions. Was that what you meant? or did I misunderstand?
Tahiti is in Polynesia
๐ ... a polynom is a function that describes a certain kind of curve with constants, variables and using a power.
In the case of field of view (staten in degrees), it ressembles something like y=1555*x^(-0.9061) if I remember well. X being the focal in millimeters. That is a quick and dirty estimation based on an excel trendline I made, nothing scientific, but it could help the extrapolation
๐๐. It gives the following result :
21mm = 98 degrees (I believe it is the diagonal)
28mm = 75 degrees
25mm = 84 degrees
Therefore 25mm is located at two third of the diagonal distance between 21mm and 28mm.
Wasn't it easy, now I look like a nuts in front of all members :bang:
But at least you know that Tahiti is not in the Polynomial island
๐
