colyn
ישו משיח
Is there any difference between the body shell of the wartime IIIc and post war IIIc?
Wartime IIIC`s had an extra screw in the top plate (on the corner side of shell, same side as the film advance knob) Postwar cameras after the early 400000 series didn`t have this anymore
Wartime shells were bare aluminum, postwar one`s were painted flat black, vulcanite also changed like twice during the war and ran into the late forties, until the sharkskin material came out in 1947/49 era
Tom
Colyn,
I`m not 100% sure that vulcanite is the same pattern, I think the pattern`s changed in 1943 and pre 43' vulcanite is different than post 1943 styled? I`m not sure all my cameras with original vulcanite are still out west with Leo for their CLA, but they should be back soon, then I can check it all out
Tom
Tom
I just picked up a IIIC in a deal with some other cameras that
has this extra screw on the side. It's serial is 4026xx which
agrees with the number on the chassis, so I guess some
wartime parts were used post-war. Shell is aluminum and
painted black. It does not have the upper ball bearing race
in the chassis, as my '49 IIIC does. When did Leica start
installing the postwar bearing race, '47 ?
Thanks,
Martin
As long as the shell has the 5th hole over the lug ring, it is from the wartime era supply that they were working through.
So, Colyn, I think there are no issues in making the change that you want to.
More to follow .... We have to start writing all of this up....😀
