counterfeiting would be if i was to pass it off as original, or present another look a like camera and place the Welta brand on it.
Counterfeiting is also if
someone else passes your work off as an original.
antique dealers would call something a counterfeit if the camera was an imitation of a Welta with the Welta brand on it... kinda like in comparison if you were to restore a old 32 ford or chevy duce and had to repaint it and perhaps a badge or emblem was missing so you went and had one made exactly the same, chromed and put it on. the car is not now considered a counterfiet but simply restored. if however you bought a 32 vauxhall and cut the body, roof and everything ect. and then placed ford or chevy embelms on it to sell as a ford or chevy...well you should be locked up LOL, thats just nasty!!
Nasty? That's insane! What I am thinking of is all those brightly colored FEDs that were being sold on Ebay a while back as "rare collector's items," when they were just spray painted or releathered. A counterfeit is what you have when you try to pass something off as something that it isn't. For instance, if you try to pass off a restored beater as a mint condition original, you are conterfeiting. As an example, in stamp-collecting, if you put glue on the back of glueless, steamed-off-of-envelopes stamps, you are counterfeiting.
replacing missing or damaged leather is restoration, to what level of quality the restoration is another matter.
It is if you stop there. If you impress the lettering and such into the leatherette though, and if the leatherette is an exact match for the old stuff, it becomes debatable. Someone could easily attempt to pass it off as a mint original -- a counterfeit.
interestingly, i remember seeing some bloke on the net will restore Ziess Ikonta's if you send them to him, more particularly he removes ziess bumps and replace the leather if nessarsary. he charges a fair bit (cant remember how much but whatever) because he takes the leather from another Ikonta and glues it on, because he says he has to because of the embossing and debossing in the leather. i bet if he could do the embossing and debossing he would. hate to think he may be wrecking a bunch of cameras just to make a dollar but there ya go. no doubt it keeps it 'more' original tho.
Well, you're assuming he is just throwing the cameras away after salvaging the leather from them. I'd prefer to believe he is painting, releathering, and selling them. C6 is the only guy I know of, or have ever even heard of, who actually
brags that he throws cameras away because of one bad part. I mean, how retarded is that?
Most folding Welta have the model name in the leather but on some of the early camera they sometimes didnt have the name. you could get away with just imprinting the lines on your Welta Sport; as i said i have two, one has Welta in the covering where the model name is usually imprinted the other doesnt have any word at all, its in very good condition so it would be visable..it still has the lines though
To emboss the names in the leather/leatherette, you'd need to transfer the lettering onto 1/16 inch sheet brass, cut it out and finish it up with a set of needle files. It wouldn't cost much at all, although it would take some time. Then you would have to use a heat press with the cellulose and vinyl leatherettes, or just wet leather and put it in a cold press. What you'd actually have to buy would be the press, a dremel and some bits, some needle files and the sheet brass. Hmmmmm.......... I wonder if you could do it with a steam iron instead of springing for a heat press? Anyway, what I would like to do is to emboss the lettering in the leatherette, but in a font I designed -- close, but not an exact match to the original. I like doing cameras so that they are
close to original, but slightly modified for the better. It's why I choose to restore cameras that are either just a step or two away from becoming landfill or that are as common as dirt; I don't want to ruin valuable collector cameras.
