titrisol
Bottom Feeder
Could be many things:
- Did you cut the film so that the corners were not square?
Plastic spirals feed better if you cut the corners slanted/rounded
- You said the camera had not been used in a while, did you have to exert excessive force to winde the film at any point?
that could have damaged the sprocket-holes thus making it more difficult for the film to be fed in the spiral
Check if the sprockets are smooth or if some have "bumps"
- Make sure your reels are dry, I generally open them and leave them to dry over paper towel/newspaper overnight before putting them back in the tank
- It is wise every so often to clean your reels
use your mom-in-law toothbrush and some baking soda to scrub them clean
rinse and dry over paper towel.
