There are two custom settings - C1 and C2 - on the mode dial that can be set up anyway you want. Actually, the C2 setting allows access to three different custom settings via the menu. You can set up all the parameters you want including ISO, AF and metering modes, turn the LCD off, etc. then save those settings to one of the custom modes.
Another good feature is the quick menu button which provides access to film mode, metering mode, AF mode, WB settings, ISO, iE parameters, picture size and LCD mode on/off via one menu screen.
Also, when the LCD screen is turned off, certain parameters are still briefly displayed there, e.g. those for changing aperture, shutter speeds, etc. when using the appropriate controls. I have a 24mm VF on mine and have enjoyed it very much. It does have some quirks and limitations like all cameras, but overall I'm very pleased with it. It's small enough to carry everywhere, and fun to use.
