Changing lens mid-roll
Cranialpush
10:30 AM
Bucks, UK
This might sound a stupid question but with an M6 should I worry about changing lenses mid-roll? I had a roll come back ruined and can't fathom what I could have done wrong apart from changing lens mid-way.
Thanks.
Changing lenses mid-roll will not ruin the film. Shutter is covering the film at all times when not exposing.
The ruined film may have been bad work in the lab.
Changing lenses won't hurt the whole roll. But when you do change lenses, don't have the camera facing directly into a strong light source. The shutter curtain rides in a set of channels, which are designed to keep the light out, but with time and wear they can allow strong direct light to leak through, especially if a lens is not mounted. I discovered this through experience.
Edit to add - this type of leak was discussed a few years ago, in this thread. The images have been deleted from the old threads, but the text might still make sense.
Turn your back to the sun to be safe.
Sometimes the light shields go bad on early M 6`s and less frequently on other M cameras and there is some streaking with the lens off. It it gets bad enough, the problem will show with the lens on the camera.
Can you describe in what way the film is ruined? Was it colour or B&W? If you give a clear description of how it is wrong then someone might be able to explain what happened.
Yup, for all practical purposes changing lenses on a 35mm RF or SLR won't ruin your film. But like Chris I have had problems with an older FED-5 in very bright outdoor light, due to the reasons he describes above.
