Voigtlander 40mm? I assume you use whole viewfinder, how do you find that, close to what you expect on the neg?
BTW thanks for sharing.
Also, to those that don't know, camera without metering no problem when fixed to one shutter speed and using a flash! As OP points out, couldn't be easier if you keep in mind subject distance..
