tomasis
nb, wonderful it looks like you're getting accustomed with M8 😀 it is not bad color shoots either. wow
Hi Cmogi10
have to say you have taken some stunning photos, and put up here. Have to ask these are on a film M yeh? with what film do you normally use, the guy with the lip ring, looks like neopan400.
You mentioned you have m8 at one point, i will be stunned if you favour this over film. IMO digital files with good glass looks great (i have rd1 with 50mm summilux, BUT use an m3 if thinking about shots a bit more. For me film still portrays life -
No doubt your going to prove me wrong here and confirm you use an m8...
jon
Bump.
I should have made clear that $2500 is a good price for a Canadian 75/1.4. The German made lenses usually sell for a couple hundred dollars more.
Here's my very first frame with a 75mm Lux acquired two weeks ago. Thanks for all the guidance that helped me decide on this.
The focus is on the foreground right at f4. At f1.4 the background was soup. 🙂
M7, PanF + Rodinal 1:50
Regards,
Rolo
M7, Lux, wide open, BW400CN
so you've finally made friends with it (i remember it was a little hairy at first). beautiful!!!
I use a 2-stop (0.6 / 4x) B+W filter and find that allows me to cater reasonably in many circumstances (using an M3 with a max of 1/1000 or Hexar RF with 1/4000 and sensible film choices). I find the filter quite easy to get on and off.i'm reviving this thread in hopes that someone can answer questions about getting a ND filter so i don't have to start a new thread....
i finally bit the bullet and will be getting one in a few weeks. mostly low light, indoor shots -- but i also thought it would be a hoot to use whilst sitting in outdoor cafes, sipping wine. i'm still using the Epson R-D1 which only goes down to ISO 200 with a fastest shutter speed of 2000. for sunlight, which ND filter would be best from all your experience? i would definitely like the option to shoot wide open.... also, how much of a pain is it getting the filter on and off (i'm getting a late German model with the built-in hood).
thank you in advance!
