28mm viewfinders
laptoprob
back to basics
1:58 AM
the original Haarlem
I struck gold I guess. I have a Kobalux 21mm coming my way. To be able to frame on the R-D1 I have found a few options for 28mm finders which seem to fit best.
The CV minifinder, normal CV 28mm finder, the Leica 28mm finder (old chrome or new plastic), Ricoh GV-2 or Sigma VF-11. I want to keep the whole thing as small as possible.
How do the various options compare? Especially in brightness and distortion.
Thanks!
The mini-finder is cute and bright, but barrels quite a bit.
I recommend the larger CV metal finder, really outstanding; cheaper, too. Better than the older Leica finders I have used.
Roland.
It is so easy to ignore the distortion! Rob is looking for a finder to keep the camera as low profile as possible. The minifinder fits the bill. Rob, why don't you go to a local dealer and try as many finders out as you can. This way, you can make an informed decision.
Pessimistic aren't we? People can only offer you opinions. You yourself can only make the choice. You asked for suggestions on finders on keeping your camera as small as possible. The minifinder might distort, but it is not objectionable. At least for me. I use it to keep the camera's profile small as well. If this is a concern, it is your only choice.
Not really pessimistic. In NYC there are a lot of stores and some carrying Voigtlander stuff. In the Netherlands only a few seem to stock Voigtlander. So I am trying to find out if the finders are out there somewhere.
They are kinda costly, so I won't just order one.
But does anyone know about the Sigma VF-11 finder? The Ricoh is 3:4 ratio, therefore less accurate.
Rob, that Komura is exactly the same as the Pasoptik (I think they were marketed under different names in different territories).
Komura/Pasoptik/Avenon/Kobalux - all the same, and all big. I used to have a Kobalux 21mm lens and it's finder was massive. One thing about the dinky little CV is that it is discontinued, so its likely you wouldn't lose money on it if you did get one. But they are not cheap at $199 new, don't know why they are so expensive.
The CV finders are too expensive for me. No matter how nice and small they are. If I need max. small, I will use the whole R-D1 viewfinder and imagine more. If I want more precise I will add the finder. Which one? The Kobalux 28 Kully mentioned. Thanks again! It is white, like the 21mm lens and it is a brightline, nice!
Sorry, Blake.
