Pre-soak or not?
marke
3:42 AM
Wisconsin, USA
When I first learned film developing 36 years ago, I never heard of pre-soaking the film. But when I returned to souping my own last year, the instructor in the refresher course I took told me to pre-soak. I've been doing it ever since, but I'm wondering what circumstances might determine when it's best to pre-soak and when it's not.
Do not presoak prior to using a two-part developer. The design of such developers has the film's emulsion sucking up the Part A developer, which is retained by the film before Part B is poured in. If you presoak, the 'sponge' is already full - Part A won't be picked up as readily (or at all) by the film's emulsion.
Diafine is one such developer - don't presoak it.
I typically never presoak anyway.
Ilford Party Line:
It is not a good idea, but the theoretical objections are rarely significant in practice, so if it makes you happy, do it.
EXCEPT, as others have noted, with two-bath developers, where it's a truly rotten idea, for the reasons they give.
Pre-soaking attracts as much religious warfare as agitation (cf agitation thread).
Tashi delek,
On Pnet somebody recommended pre-soaking if using a jobo and a film with short dev-times, I can kind of see why but even with less than 10 minutes it usually works for me.
martin
Somewhere I read that it helps the emulsion swell... or something to that effect.
I pre-soak. Makes me feel better than pouring developer so rudely on an otherwise fast asleep roll of film (however crudely it was separated from its metallic womb of the canister). 🙂
Believe Ilford. After all, they make the film. I imagine they run countless rolls of test films. If they say it makes no sense to pre soak, then they're probably right.
I presoak 120 film because in my experience it prevents some patches of underdevelopment. More like disks of underdevelopment. Fairly subtle, but visible in clear skies.
I don't with 35mm and have never had uneven development. This for 40years plus.
Why the difference? I can't figure it out.
I use Jobo inversion tanks, lots of agitation to start then not much.
I never pre-soaked until two years ago, but now do it 100% of the time. Kind of makes sense, to me, that a developer will have a better chance of penetrating evenly into a wet emulsion that a totally dry one.
I have no idea whether I'm right or wrong. I do like the results I get so will continue to pre-soak.
Jim B.
Ten years ago I worked in a boutique b&w lab in NYC; the guy who started it, on the strength of his processing skill and reputation, taught me to do it, at least while I worked processing film in his lab.
Now out on my own, I've noticed some film/developer combos are better without a pre wet, where others seem to give better results with one. I don't worry about it too much- but I will say that certainly the advice not to pre wet with any two bath developer is correct. I also don't pre wet any film when using Rodinal 1:50 (a favorite).
Om the other hand, if I'm processing in HC110, Ilford FP4 and HP5 both look better to me if they get a pre wet- as do Kodak Tri-X, and a few other films. Your mileage may vary.
I used to be one of the religious ones on this topic, but since I've learned better, I got over it.
...I also don't pre wet any film when using Rodinal 1:50 (a favorite)...
Interesting what you say about Rodinal. It is, as I understand, an extremely active developer and as such begins to act immediately and with great vigor (so to speak). So, if there would be a film to pre-soak (according to the reasoning of pre-soak zealots 🙄 ) Rodinal would absolutely be the developer to do that with. Go figure. Not one iota of this makes sense to this 20+ year black and white film guy.
Thanks guys. As I stated earlier, I've been pre-soaking since my refresher class last year, except for a few times I felt courageous. And I can't say I noticed a difference. I had felt that it might allow the film better/more even absorbtion of the developer, possibly eliminating any air bubbles. But in reality, I have never had an air bubble on film in my life, and couldn't see how it would happen if you agitate and tap. So I guess I'll just eliminate that step from now on. And that means more drinking water for my dog too. 😉
Pre-soak may help cut-down on antihalation stuff
On some of the Kodak film, pre-soak may help get rid of the antihalation coating.
I think it was T-Max film that usually has more antihalation coating than TriX.
But if you don't have problem with purple cast after souping, no need to do it.
-PB
-PB
Excuse my ignorance, but what exactly is antihalation coating?
Ever so often I do get a bit of a purple cast, but I thought that was either do to a spent fixer or not enough washing.
Thanks.
