Rear cap for Mamiya 6 50mm?
vdonovan
Vince Donovan
10:19 PM
San Francisco
Any idea where I can find a cap for the back of my Mamiya 6 50mm lens? It's an odd shape and I've been through boxes and boxes of caps at camera shows looking for something to fit. Any ideas?
thanks,
Vince
Hi Vince - are you sure we're talking about the same camera system?
There is no 100mm lens in the Mamiya 6 system (only 50, 75, and 150mm), and I'm quite sure that all three of these lenses take the same rear cap because I own them all and looked at them to double check before writing my response above.
This is correct.
For the Mamiya 7 which has a different size mount (unfortunately), there are two rear cap types: one for wide angle, the other for standard focal lengths.
Thanks for your responses. I should clarify. Yes, it's a Mamiya 6, and yes I have the 150mm. That was a typo above.
I don't have an official Mamiya rear cap for either lens, but I found a flea market cap that fits the 150 pretty well. The 50 has a rocket-nozzle-shaped element at the base which means it would need a pretty deep cap.
I actually emailed Mamiya about this and received no response.
thanks again for your comments.
