Suggest a good scanner under $250?
hyokjae
5:00 AM
California
Hi everyone,
I am looking for a (new/used) scanner with which I can scan 35mm negatives (b&w 80%, color 20%) - probably a few rolls of 36 exp per month. My budget is max. $250. As there are so many scanners to choose from, I am seeking a collective wisdom of RFF members. Would you please suggest a scanner for me?
Thanks.
-hyokjae
The Epson 4490 is decent enough for 135 and amazing for 120. It's an especially good choice if you're only scanning to post online, because at higher resolutions it is quite slow.
OK.. Epson 4490 & V500 are on my list. Thanks for your suggestions.
It looks like some RFF useres are using Canoscan 8800f. Any opinion on this scanner for 35mm negative scan?
Thanks,
-hyokjae
Look for a used Minolta Scan Dual IV. Since you're doing mostly 35mm B&W it would be perfect for your needs. Be patient...you can still get them for around $250.
I do not recommend Minolta because the scanning software is outdated. If you are using a newer OS you might have problems. You will probably end up using VueScan which also can be problematic. You can't go wrong with Epson.
I have a V500 and it's okay. I had a 4490 and the glass deck collapsed on me--slowly, no shards of glass flying everywhere! I use a betterscanning.com MF holder and both a 35mm and 120 ANR glass insert. More often than not I'll just scan negatives right on the glass with the ANR insert holding the negative down and flat. Good enough for the web.
From experience I found the Epson 4490 quite acceptable. It is well below your budget especially if you snag the refurbished one on Epson's website ($110). The V500 is probably a new version of the 4490 or similar so you'll have to check the specs. Keep in mind more dpi and such isn't necessarily better but it definately means larger file sizes so if you have gigs and gigs of hard drive storage...
I upgraded to the Epson V700 for large format capability which also includes much nicer negative carriers, for example I can run on 24 exp roll of film in a single scanner load, etc...
Convenience, speed and ease of use are more important to me because I can always re-scan a special image at super-duper resolution later but just getting a roll into the computer must be quick and pain free.
It's been mentioned, but the Epson 4490 is a good scanner for the low price. Snag one from Epson's site and you won't be sorry. It handles 120 very well, and the 35mm holder is a little flimsy, but usable.
Thanks for all your suggestions.
I decided to go with either Epson 4490 or V500. Does any of you know any difference in quality of the film holders between the two models?
Thanks again.
-hyokjae
There is little or no difference in the film holders. By the way what part of the state are you located in? Since I bought my Epson V700 my V500 is looking for a new home!
