I note very little positive comments on the plustek series of scanners. I see online there is a new version out, the 8300i SE, which has little in the way of reviews, Anyone here use them ?
I use the much earlier 8100 version. Honestly, I don't think much has changed in the way of performance between that model and more recent ones; I think they just put a new version of SilverFast in the box and change the version number, but I may be (very) wrong.
Prior to buying the Plustek, I was mostly printing for the "real", final version of an image and using a Canoscan 9000f to digitise the negs, creating a searchable digital archive, and for online use. I was never overly happy with the Canoscan, but it was passable in the late 2000s, when screen resolutions were lower and displays were lower quality; on a modern device, scans from a Canoscan - even at the highest possible resolution - look bloody terrible. In comparison, the Plustek is almost too good - every single bit of grain will show up much more prominently than you'd get with a good wet print.
Here's a comparison between the two scanners - nothing too fancy, just a 100% crop of a quick grab shot on APX 100. Hilariously, the Canoscan version is actually the higher-res of the two (approx 3300x2200px vs 2600x1700px):
Here's the Plustek version of the full frame, so you can see how tight a crop this is:
I didn't add any sharpening to either of the individual files or the merged comparison in the process, either - what you see here is exactly what you get out of the scanner. The difference is so vast that I actually think there's more detail in a 35mm scan from the Plustek than there is in a 120 scan from the Canoscan, which is just
so wrong.
The TL: DR? You get higher resolution than the average flatbed and the price isn't a whole lot higher, so the Plustek is obviously a better choice if you're looking for a dedicated scanner. The downside is you're limited to 35mm only, and as the neg carrier feeds in one frame at a time, there's no batch scanning to speak of. With the Canoscan, you can put 12 frames (2 x 6 frame strips) of 35mm into the scanner, adjust the exposure and settings for each frame, then start the scanner off and walk away. With the Plustek, it's a more involved process - you have to manually push the carrier over, prescan, adjust exposure, then do the final scan. Luckily it's quite fast per frame, but I still want to have a TV show or something on in the background while I do it if I'm scanning a whole roll.
I think wet printing and scanning the print is still a higher-quality option if you know what you're doing, but that's an even more involved process, so for 99% of things, the Plustek is more than good enough for me.
