Zorki S Help me please
KGB-Spion
4:54 AM
Dear Users,
I am not a newbie, but sometimes I have no idea ...
I have restored an old Zorki S but now I am faced with an other bad problem - the rangefinder calibration.
As it is written in many websites, first You have to do ist to set it to a closer distance (1m) and calibrate it.
Then You need to set the lens at "infinity" and recalibrate it again. BUT- My Problem is - 1m DIstande works finde and infinity mode works also - but when I am pointing it on an objact which is 2 meters away, I get different values :-(
It will be even worse - when I am zooming on an object 8 metres away, it shows me, that it is 10 metres away.
PLEASE tell me how to solve this problem - and sorry for my bad accent - I am from Germany.
Best Regards,
Denis
Okay - Now its a little complicated --> I have tried those sites ! But somehow although the rangefinder is looking quiet proper at "intinity" and "1m" it gives me still wrong information on other closer distances like 2 m or 3 m --> Is that OK ?
Maybe I don`t need to pay attention to those numbers ?
The other thing : I use the Industar-22 and it has a small black stick on the objective, which is intented to be moved to the distance You want --> 1m or 2m ... BUT - it`s bright is 2 mm ! So do I have a tolerance or should I place this small blackpainted indicator right in the middle of the range values ?
Again - thank You for Your help - YOU ARE GREAT !
A OK Thanks - I found the section and I am glad to read the same things I made !
OK - adjusting the sensor head is a creepy procedre, cause in my case, it didn`t help at all (OK - maybe a little bit).
I also realized, that the lens doesn`t need to be pointed exactly at the "infinity" mode !
Something between the 20m and the "inifinity" will do it, too , cause You won`t really realize the difference at all.
Thanks !
Best regards,
KGB-Spion
I have a standard usual calliper and I could set it to EXACT 28,8 mm - please tell me how to place it on the cam, so that it is really precious - pleeeaaase!
Measure from the front of the lens mount to a piece of film on the pressure plate, try it in several places. I wouldn't worry too much if it's not absolutley exact, take some pictures unless it's a long way off 28.80mm. Then decide...
