Thanks for the link.
They seem to have only tested the quality of UV filtering, not the coating and how easy the filters are to clean.
B+W also make MRC filters with alloy rings that are sold on eBay. They are less expensive than the brass filters and the glass is identical.I am yet to put a cleaning/coating mark on my B&W filters while the hoya are so easy to damage...
When cash and availability are not crazy, and for important lenses, for me, it's B+W all the way...
Other than UV filtering, B+W MRC filters are as good as it gets.In the latter categories [flare, vignetting] the MRC filter has no flaws. It is worth adding that the B+W filters have the best build quality and they are very easy to clean.
BTW who buys giant 72mm filters? The Nocti is 60mm and its the largest element in the lineup.
Starbucks still has ashtrays on the outside patio and I have them throughout the house, including the darkroom. Got a roach clip or two also just in case.
Doesn't anybody remember the old trick of blowing a cloud of smoke under the enlarger lens when you wanted just a bit of diffusion?
