older 35mm lux asph vs new version.
qruyk12
12:07 PM
Canada
i know there was an older version of the 35mm lux asph made in the early 90s. how does it compare with the newest version? what is the older version worth?
I cannot tell the difference between the two versions, Aspherical and ASPH.
I would guess that the older version in new condition might be worth $3000.
Just a guess.
In general terms, the first version was engraved on the front rim with the full word "Aspherical" and the second (current) version has the letters "ASPH.". There are those who say the v.1 has a more pleasing signature than the v.2, others can't see the difference, so the usual arguements break out. Suffice to say that the v.1 is discontinued, collectors and users both like it, and AFAIK the v.1 commands a higher price than the v.2.
The only 2 differences between the older and current are the following:>
1. the older is marked aspherical by the lens front, the later by ASPH
2. in the older one of the groups is glass, wheras it is moulded
the cost of the earlier is 6K
If I remember right - the original 35f1.4 Aspherical had two Asph elements while the newer version had one.
I have used both and from the point of sharpness I did not see a difference. The first version seemed to control flare a bit better than the Version II.
Someone - can't remember who - did a side-by-side comparison a few years ago and pronounced the Aspherical marginally better than the ASPH. I can't even remember whether it was due to resolution or contrast or or corrections or whatever.
The Aspherical has two ground aspherical elements, while the ASPH has one pressed aspherical element.
The Aspherical goes for roughly twice as much as the ASPH (or almost) due to its collectibility. Less than 2,000 Asphericals were made. There was a very high reject rate. I have see the Aspherical go for over $6,000 US.
The Aspherical hood is certainly more obnoxious, being larger and more akin to the 21 & 24 Elmarit hoods. The ASPH hood was an improvement. The hoods are not interchangable however, due to the Aspherical and ASPH having different front constructions.
Having used a 35mm Summilux pre-ASPH for many year as my main lens, when I heard about the highly corrected 'aspherical' (1st) version sometime in the early 90s I thought I'd get one. But at the original $4,000 price I didn't want it that bad I guess.
Later I traded the old Summilux for a new ASPH version (which I regretted shortly, still like the look and handling of the old lens) and had both a Titanium and Chrome version of those. Heavy but steady.
Then a first version came by at a decent price and, "if I had to have one lens, this is it".
Differences between the two versions?
The first version has two 'hand-ground' aspherical elements made in the same basic way that the 1st version 50/1.2 Noctilux was made. The 'hand-ground' term here means highly 'supervised' and quality controlled precise specialized grinding machines. Each lens needed an 'artists' touch' to get it within tolerances, very hard to make with many rejects I heard. One woman made this lens in a back room at Wetzlar. Because of this the original production run of 2000 was scaled back to 1000, and the actual number made may have been in the 700 range (no one knows for sure). I had heard that the lens barrel itself would have needed another production run and Leica decided against it with the glass costs and difficultly. Although the element layout is basically the same as the ASPH the 1st version, front element to back element distance, was a bit shorter if I remember right.
Photo-quality is basically the same between the two. Sharpness/contrast comparable, if there is a difference you'd have to really be looking but may be there especially with sample variations. I never did a detailed comparison when I had the two, just some side by sides to see in general, but the only differences I would say is the 1st version is more flare resistant and seems to have 'smoother' bokeh, that is the transition of out of focus seems more gradual and even (or at least its two of the qualities of this lens I see and appreciate after using it for a time now).
How the 1st version handles is maybe the major difference that's apparent. The lens barrel itself is a few mm shorter and the rear element is slightly shorter from the lens mount. The 300gms is slightly less too than the ASPH 315gms (Leica specs.). The 1st version has a grooved focus ring😀 along with the finger tab. When I had the ASPH version its something I always wanted and spent time thinking of a solution which never was perfect (rubber strip in the focus ring). I like the older style plastic/nylon finger tabs of the 70s/80s, there's a nice 'hump' on the side of it that works like a raised bridge to put your fingers, and the contours are not so sharp, a 'softer' feel to it. The 1st version tab is placed a bit higher on the barrel and fits my index finger perfect, and with my thumb on the grooved focus ring its quick and well controlled. But the tab becomes harder to use in the close focus range (unless you only use the tab) with the advantage being I switch to the focus ring with both index finger and thumb.
Focus is very smooth on both with the 1st version having a longer focus throw and the added '0.8' m engraving. I like the longer focus throw in general especially with a fast 1.4 lens
The aperture ring on the two ASPH version lenses I had was never the way I liked it, too easy to move and soft clicks. It was just OK for me, and some folks may like it that way (the Leica rep that showed me the aperture action was very proud of it). The 1st aspherical version is a bit more old style, the aperture is controlled internally by two pins, not one as the ASPH, and there are 10 blades instead of the 9 of the newer ASPH making a 'rounder' aperture opening over the f-stop range.
I much prefer the clip-on style hood of the 1st version with its hard plastic clip-on hood cap (that soft rubber lens hood cap of the ASPH was always falling off). The hood tightening ring on the ASPH just seems odd and looking for the aperture ring with my fingers that's the same size and style as the hoods ring I turned it now and then by accident. The 1st version hood is also a bit thicker plastic (not larger) and maybe more durable. Anyway the original ASPH can use the 4th version 28 Elmarit's hood (which I did) and is the same design as the 1st version hood.
The 1st version 35 Summilux aspherical these days is going for $4,000-6,000 (bargain - boxed and mint unused condition), which if you think of it with inflation can be less than the original early 90s $4,000 price tag. Is it worth the extra money compared to the newer [new or used] ASPH version? In actual photo quality I would say no (to me). But then I got mine at a good price and at the time the Yen was a lot less than the dollar (it was a 'bargain'). These days the ¥/$ are more equal and its more an individual/cost judgment call, and if you can find an 'aspherical'. Both lenses are great, and there is something to be said for a well corrected fast wide-angle lens as a universal lens on a Leica. All in all, the 1st version is fairly light (the pre-ASPH is 250gms) and not so big (comparable to my 50mm Summicron) and I do use it without a hood most of the time which makes it even smaller, it handles superbly, and it never fails optically - what more can you ask of a lens?
I do use this lens, its not a 'collector's lens, but I don't 'throw it in the bag' with out care either. Now if anything happened to it... and it needed repair... may the Leica God's help me:angel: I do keep a B&W MRC filter on it.
Here's a photo of the 35 Summilux aspherical compared with a 50mm Summicron 3rd version (BTW that's a very rare 3rd version 50 in black paint, special order and maybe only a dozen or so made, engravings are different and of course the BP vs normal anodized black)
Hard to find 35mm lenses
From the Texas PhotoForum..........no, these goodies are not mine. I'm not sure that I would be comfortable with lenses like this.
I am selling some of my Leica rarities:
First up
Leitz 35mm 1.4 Summilux "Aspherical" First version, Black, two hand-ground aspherical elements (all asph. version have 1 molded element)
Super rare-less than 1000 made.
The lens is super sharp with incredible rendition.
Glass is flawless. It is near mint with only slight deblacking on the hood area.
Original hood, caps as well as the original box.
Asking $5995 or BO
Second up
Classic, 35mm Summicron, Wetzlar,First 8 element M2 version, chrome
Totally mint, absolutely pristine glass, barrel and mechanics.
Wonderful look (bokeh), A gem.
Asking $2,500
http://www.texasphotoforum.com/forum/buy-sell/114501-fs-leica-m-rare-lenses-hard-find-accessories.html
