marduk
Thanks bro. Can I check out your M3?
The original ad is now gone but here is the pic: http://www.rangefinderforum.com/forums/showthread.php?p=1085990#post1085990
Checking out a Summcron Dual Range 50 f2 tonite. What's your thoughts? It's around 850USD.
hello from a fellow singaporean!!
first, congrats on ur purchase, it's a really good price for such a nice camera!
the dual range is a really really good lens. it's my favourite since getting it. problem is, i've gone through 3 to find a good one. usual problems are hazing and scratches on the rear element's coating due to improper cleaning.
i'd suggest a version 4 35mm summicron if you can find one. for tele i'd go for a 90mm tele-elmarit, the thin one, for stealth.
check out this strap:
http://www.youtube.com/watch?v=yWaT_qwnQ38
it's really easy to diy and it works really really well!
A reminder about the close-up "advantage" of the D.R. 'cron. It DOES NOT EXIST if you base it on area covered A 90mm lens at its closest focusing distance covers exactly the same area as the D.R. Summicron with the eyes in place. A 90 doesn't require you to stop and put the eyes in place, and you can buy a black 90.
