It took a while to find this; long, long ago bulk film came in tins of 50ft. So that's 10x 5ft lengths, which is 36 exposures...
Regards, David
Dear David,
Except that no, it is't. A standard load was 63 inches, 1.6 metres. And besides, 50 feet is an imperial measure. Germany used the metric system by the time that the Leica came out, despite the fact that the mount is 39mm x 26 tpi (they were a microscope manufacurer, remember, and Royal Microscopical Society threads were the first in the world to be standardized).
Of all the explanations I've seen here so far, I have seen none more convincing than the one I put forward earlier: that 36 exposures, with one or two over if you were lucky, was the longest you could reliably stuff into a Leica cassette, the dimensions of which in turn were dictated by the size of the Ur-Leica which took 50 darkroom-loaded exposures (no cassette).
Had there been an internet at the time, no doubt it would have been full of people snivelling that Leica had screwed up and failed to fit 40 or 50 or some other round number of exposures in.
In those days, developed films were commonly stored in the full roll, but as soon as they began to be cut and stored in sleeves, 36 was an obvious number as you can cut 9x4 or 6x6; the only other obvious candidate is 35, cut to 5x7 or 7x5. You can't get 40 or even 39 in; 38 is 2x19; 37 is a prime number; 34 is 2x17; 33 is 3x11; 32 is 8x4 or 4x8, but why not have the extra 4 frames?
One frame-plus-rebate, measured from my MP, is 39.5mm, which x36 is 1.422 m. Add two frames on the spool end (the spool on a Leica cassette is slotted and takes the film trimmed to a blunt point) and you're up to 1.50mm, then a 10cm tongue and a couple of blank frames in case of fogging at the beginning and -- surprise! -- you're at 1.58 metres or 62.2 inches. At this point, 1.6 metres/63 inches is unanswerable.
Now: it's 1933 or so, and Perutz, Kodak and others want to sell their film for Leicas and Contaxes; 36 exposures (or 37 if you're lucky) is already established; what are they going to go for?
All this stuff about Barnack's arms and so forth is not really supportable, given that the Ur-Leica used a longer loading; Kodak's deciding on 36 exposures is clearly not the case, given that this loading was already well established and that the two most popular 24x36 cameras counted only up to 40 anyway; how much more explanation is really needed?
Roger
