Visible body difference between Leica M6 and M6 TTL
psb
2:42 AM
It's an honor to join this forum. I've just purchased a Leica M6 TTL .72 on Ebay. I've yet to receive the lens I've purchased from B&H. My question: Are their any visible differences between the M6 body and the M6 TTL body? I realize once the lens arrives I'll be able to tell the difference re: metering, but I just wanted to be assured I received the correct model. I'd be most appreciative for any input.
The TTL body is a few mm taller than the "classic" m6. You can clearly tell when the two are side by side, the proportions are just a little different.
The shutter speed dial is bigger on the TTL, and also turns the opposite direction.
Thanks so much
Thanks so much
Thanks for your info. Is that to say the shutter speed dial turns from "off" counter clockwise to the higher speeds?
if you are using a DR summicron 50/2, you may need to remove the tab screw on the close-up apparatus to mount it. This is because of the 2mm difference in the height between M6 and M6TTL.
I wish I could afford the Summicron
I bought a far far cheaper, yet supposedly quite good lens........ a 28mm f2.8 Biogon T*ZM
One last question if I may..........
Promise....last one
Will a Vivitar 285 flash work on an M6 TTL? I read on a leica forum that that was a BIG mistake, although it could be done with some particular flash sync cord. It was actually mentioned by two individuals that a Holga 120 flash actually worked quite well. After all the money I just spent, a $20.00 flash would be a relief 🙂 , but I'd hate to see my beautiful 285 go to waste. Any thoughts?
It depends on the 285. The newer ones might be ok, but you should check the trigger voltage first. I have a couple 283's I use: one that is fine, and one that has a trigger voltage of over 120V! (That one stays slaved and OFF the camera of course...!)
-Brian
Vivitar 285 is NOT voltage safe, so please check before use. The newer model Vivitar 285 HV is safe.
In any case the Vivitar 285 is not a Leica TTL-compatible flash as it meters through a thyristor module attached to the front of flash body. It's a good flash anyway and you can use it provided that the trigger voltage is on a safe level.
For TTL metering with your M6 you need a Leica TTL compatible flash for M-bodies. Unfortunately you don't get one of these for $20.
snip (2) The shutter speed dial is bigger than that of the M6, handy when wearing gloves, and some people can turn the dial with one finger. (snip)
I have a question to M6 users: Can you guys turn the shutter speed dial with one finger? I find that I can use one finger only when going to slower shutter speeds. When going faster, I have to use two fingers (edit: index finger and thumb).
Bob
^Nice lens!
Holy smokes. I just used that lens for the first time and had the images developed. I'm floored with the quality. It's incredibly sharp. I know very little about the Leica system, but if I paid this relatively meager amount for this lens, I can only imagine the sharpness of a Summicron.
