Thardy
It will be a sad day when my little film scanner gives up the ghost.
A slower way, for certain. But I'm not thinking that one would want to digitize every frame, either.Not for those people interested in scanning color (either neg of slides). No digital ice means ages spent cloning out dust.
Back when I was developing and printing my BW, I made contact sheets of every roll and then printed the few that I really liked. And as clean as I tried to keep the darkroom, the negs, the enlarger, etc. I did have to spend at least a little time dust spotting. I always thought of that as just part of the process.
With a digitized frame, dust spotting is a one time process, I think.
Rob
Hire a Flextight out for a day once a month, once a week, whatever/whenever.
Why have something bulky and expensive at home that you have to service and look after when you can go to a studio that has one? @ £75 Per Day, why not? It's going to be cheaper than buying and maintaining a scanner that offers similar quality yourself.
Not that I would complain if more options where made available, to the people that want one at all, of course..
Most people live nowhere near where a commercial for-rent scanner is located.
I...
The three major manufacturers still producing film cameras are Leica, Zeiss and Cosina. It would make sense for one of these companies to involve itself in the production of a high quality reasonably priced scanner for 35mm. ...
I agree that the days of quality film scanner is probably never going to come back. Sad as it may be.
But looking at the problem a completely different way, I see a glint of hope that as the camera sensor technology improves in resolution and the amount of recordable signal-bit, soon we'll be hard-pressed to distinguish between an image from a Coolscan vs from a DSLR equipped with a planar-type lens.
Then, what should follows is a cottage industry of either commercial or DIY gadgets to properly aligning and back-lighting film frames. If we can take a cue from lens adapter "industry," this is not too far-fetched.
That was my first thought, Will, some quality copy stand that will give the quality of a good scanner.
As far as dust is concerned, it's there no matter how you scan.
I agree & I almost made the same statement. If I was going to be making prints I would surely want a dedicated film scanner. I think thats where you really would see the quality of owning one, provided you had a good printer. Looking at it in that aspect of shooting film & using a hybrid system to convert to digital just to make a print, I wonder what the cost of doing so would be compared to printing in a traditional darkroom. I have a darkroom for my b&w stuff but I can't afford the setup of scanner plus a good inkjet printer. Then the cost of inks are very expensive last time I checked. So I think better before one goes this route just go totally digital & any film one should send to a pro lab for high end prints.i think scanning for the internet and scanning for prints are two different beasts Greg.
most of the benefits of a dedicated, high end scanner are essentially nullified by jpeg compression.
What am I missing here? You guys make it sound like it's the end of the world as far as scanners are concerned. Did Epson go belly up on film scanners? I look at alot of photos and I don't see any difference in a photo scanned on a Nikon scanner than a scan on a Canoscan whatever flatbed. MOF I've seen some good scans from a cheap flatbed, least good enough for viewing here & on flickr. So I don't get all the negative riff.
Manufacturers saw a market for dedicated 35mm film scanners and filled it until there was not a large enough market left to sustain the profit in supplying it. People are rightly nervous about the future of their old 35mm negs WRT being able to do anything with them as for as being able to print them at large sizes. There is no problem, so far, in being able to digitize them for web use as most flatbed scanners can do that. The question with that is when will manufactures not see any advantage to having a flatbed scanner in their line up that can do that. If it was really viable from a profit POV to produce a dedicated 35mm film scanner to a price point that most could afford you would be seeing them. I hope somebody does but I am not counting on it.
I have done this a couple of times at photoVillage in NY @ $250 per day (£75 sounds like a good deal). I have mixed feelings about the whole experience. On the plus side the speed and resolution of the scanner is impressive.Hire a Flextight out for a day once a month, once a week, whatever/whenever.
