Mephiloco
Both of these are Tri-X at 3200, souped in rodinal
TriX at 250 in HC-110 using Ansel Adam's compensating method:
What's that? Could you point us to an instruction/link? I'd love to know.
I haven't actually tried it; I feel that Tmax 3200 or Delta 3200 both give MUCH better results for speeds over 400.
Depends on what you want. Some people like the high contrast look of pushed Tri-X. I want some shadow detail, which pushed 400 films just don't have much of. There's no 'right' on that, depends on your artistic style.
You just reminded me of something that I've been doing differently lately. When developing Tri-X shot at EI 1600, I've brought my agitation down to two very easy inversions every two minutes. I think it's kicking down the contrast a bit than my old way of 3 inversions every minute.
Have you had any trouble with uneven development? I just cannot seem to make gentle agitation schemes work for me. I have tried several times over the years with different films and developers and every d--m time I get severely uneven development, with the top and bottom edges of every frame on the roll denser than the center areas. Sometimes its so bad that I can't even make it look good in Photoshop by selectively darkening the offending areas. Tri-X shows much finer grain with gentle agitation but the uneven development destroys the images...so I just deal with the grain, which isnt bad in any case, but still it frustrates to know it could be better but I can't get it to work.
Nothing uneven that I've noticed, Chris. I do complete inversions, rotating 360 degrees, then tap twice.
The above post is for Hans.What's that? Could you point us to an instruction/link? I'd love to know.
Tri-x in diafine is a winner.
