Yes, good results I had trouble with Rodinal 1+50 and TriX, at 250. So I went back to HC-110h. I still wasn't 100% happy so I added some Rodinal to the mix. I'm liking the combination, I still have some stumbling to do to get it exactly where I want it, but I think I will get it. Advantages are: low grain, great highlights, midtones where I want them, and HC-110 + Rodinal does the shadows. Here is one:
srtiwari and Bingley, yes, I'm still not there, this negative didn't have enough Dmax, but I'm getting there. The highlights, now this is just me, really sparkle with this combination. So for TriX at 250, and this is 35mm, I do HC-110h 500ml and then add 2.5ml of Rodinal (straight from the bottle), 11:30 minutes, 30 seconds initial agitation, the 3 inversions at 10 and 5 minutes counting down, at 68 degrees F. My problem is I use so many different cameras I'm introducing another variable. I have to do some serious testing. But this little miracle, at least for me, is holding promise. This is 35mm early morning, darn it a new and unknown camera, but I like the shadows and the highlights.
Huhm Rhodes photos don't seem to have that "bite" and contrast of Rodinal that I often see, wonder why is that?
In my experience Tri-X needs to be exposed @ about EI 250 for Rodinal. Also, some of your shots, while in bright light, are of scenes with relatively flat/low contrast.Hmmm, do not know. I used 300ml for one roll in my paterson tank. And used 5,88 ml of rodinal.
Well, that my next experiment. I choose iso 400 because my first photos were at low light. The weather was always overcast. My first here, was taken in low light, it was almost 5 o'clock or something, almost nightfall here now.
How can I resolve the "relatively flat/low contrast" issue?
