Trius
Waiting on Maitani
Keith: Yes, it does.
As an owner of both a champagne and black OM4-T, I can assure you that they both work well with a "male" owner!! 😀Chris - okay. Well then I won't feel bad if I ever buy one for myself.
I have two black and one champagne. I admit though that the champagne was bought for a girlfriend. When she left me for another dude, I kept the camera....it works just fine for me!
well yes of course, so can the thermometer used to check the xmas turkey be misleading if not used correctly, but all things being equal, assuming the user has some sort of knowledge (IQ in the region of using a waffle maker should be sufficient, as apposed to being able to operate a VCR 😀) there can surely be no argument that incident meters are the most accurate meter and best tool for studio work e.g. still life and model work..the reflective is used when its not practicable to use incident or inconvenient . with the method Keith described as using a reflective meter for still life, an incident meter would be far simpler and more accurate by a long way
normally Keith one would indeed want accurate readings, more so when you are trying to create and shape the light, normally you simply move the incident meter to the different positions to see the difference in f stops between them...thus creating your low key or underexposed areas precisely to the levels you wish...reflective metering is averaging what ever you are pointing it at (which is why spot meters are next best because of the smaller area metered) and largely relying on a roundabout, close enough, lucky dip or surprise endings...still, that can be half the fun in not knowing exactly what your getting,...more power to you, and its certainly not to say reflective cant be used...heck it can be done without meters as well. I'm simply relaying the normal studio methods that are commonly used and taught
Keith - you might not have been taught much but haven't you learned a lot, from experience! What comes over is that your gut instinct about lighting serves you very well. Can't think why you want an OM-4 or Ti. It seems to me from the results you post that you do quite well enough with your present equipment. I think you turn out some great pictures.
those happy mistakes are great, we all have them, but wouldn't it be nice to create/repeat and shape them at will though..none of the people that i taught in the studio considered themselves unlucky to have the extra knowledge, quite the contrary!
what is so special about 55mm/f1,2 ? I'm trying to decide to get either her or 85mm/f2,0.
It's not that great of a lens - get the 50mm f1.8 or 1.4 instead. or the newer 50mm 1.2
