wakarimasen
Thanks Robin - I am downloading now.
Best regards,
RoyM
Best regards,
RoyM
...Unfortunately, when you scan B&W negs at 4000 DPI you can get some odd things going on w/ the grain. ...
I chuckle every time someone posts something like this. This forum is filled with men who spent thousands, sometimes tens of thousands on Leicas, Hasselblads, and other costly cameras and their expensive lenses. Then they cheap out and buy a scanner that isn't capable of realizing the full potential that the films exposed in those high end cameras can deliver. Why bother? I use a Nikon LS-8000 with glass carrier for everything. Yeah it isn't 6 times as good as an Epson, but even 10% better makes it worth every cent to me. The scanner (and printer) you use are the interpreters of your negative or slide....all your money spent on good gear, your time getting the pic exposed right in the field, the time you spend editing in Photoshop are all negated if you compromise in scanning and printing.
The Epson 3200 does quite a decent job with the standard film holders, but you might be able to get a bit more sharpness with a custom, adjustable holder. I haven't bought one of these yet but am sure giving it serious thought.... http://www.betterscanning.com/scanning/mainintro.html
Be sure to look at this link on the above site... http://www.betterscanning.com/scanning/vb_advantage.html
This is the sort of results I've gotten scanning 6x6 Rolli negs with the E-3200.... http://photo.net/photodb/folder?folder_id=627693
Most of these are E-3200 scans of 4x5" negs, 3 people shots were with 6x7 roll back.... http://photo.net/photodb/folder?folder_id=613188
Be forewarned, scans of larger negatives can generate huge files that may strain your computer power and storage space. A full resolution scan of 4x5" can generate a 500MB drive clogging TIF. Best keep things reasonable.
Presently have about 3TB of storage and recently upgraded to an i7 machine running Windows7 64 bit. Larger files are now much easier to deal with. Have been trying to archive half a century of my personal negatives as well as some my father shot while he was young. What a job!
Glenn
I just bought a Microtek 120 artixscan with 3 holders. I compared the scan from the microtek to a scan from the nikon coolscan 9000 and there is such a subtle if any difference. The only problem with the microtek is it doesn't have digital ice. I just blow off my negs before I put them into the scanner and really don't have a problem
I am suprised no one mentioned this scanner.
That looks like a very nice scanner - I have an i800, and it's da bomb for a flatbed. Unfortunately Microtek has scaled back their offerings in North America (or is it just the US) and does not sell that scanner here.
You cannot use digital ICE dust remover with silver emulsions.
And to repeat a simple point: the final output quality is primarily dependent on the quality of the weakest element in your imaging chain. If we could shoot on film with a MTF of 1, with lenses with a MTF of 1 and scan with a scanner with a MTF of 1, then we would have no quality loss. Alas, we have to accept lower MTF values, and the final product is the MULTIPLICATION of the three. So, it makes as much sense to use a sharp film and a good lens, as to use a good scanner. People who buy a Rolleiflex or Hasselblad and then scan on a flatbed get a result comparable to shooting with a Seagull and scanning on a good scanner. It might appear to be more sexy to go around with a nice camera and scan in the privacy of a closed room on a crappy flatbed, but the end result will be a Seagull shot. To who says, that it depends on the enlargment size, I reply - sure, but for postcards, you might as well use a half frame compact film camera, and avoid the expense of sophisticated gear.
I have said the same thing many times on RFF and few are willing to listen. People buying top-level expensive cameras then skimping on the scanner or using a cheap printer. Why bother.
Everybody doesn't have the budget for top-level, Chris. My most expensive outfit is the Contax IIa with a CZJ 5cm/2. Top-level in its day, for sure. Less than $200 for me. My Epson 4490 cost $80 used. Works for me, and I want to be able to discuss this with other members without the incessant "don't even bother" from pros like you, or from wealthier amateurs than I am.
For an amateur, a top-level scanner is unlikely to pay off versus using a flatbed most of the time and giving important scan jobs to a pro shop.
@ Disaster Area: You've posted that staple picture before, haven't you? I like it.
... If we could shoot on film with a MTF of 1, with lenses with a MTF of 1 and scan with a scanner with a MTF of 1, then we would have no quality loss. Alas, we have to accept lower MTF values, and the final product is the MULTIPLICATION of the three. ...
IF, and WHEN you find a shot that you want to put on your wall (or a clients) THEN send it out and do it right.
