historicist
I can second the recommendation of the L-508 type Sekonics (I've got a L-608, but all of the Sekonics in that series are fairly similar). Great spot meter with direct readings (no fiddling with calculator dials) coupled to a good incident meter.
I use incident much more than spot and a dedicated spot meter doesn't appeal since it means I have to carry two meters at once - spot meters are slower to use since they require a bit of thought about what you want to meter.
The L-408 is great too and cheaper - but it doesn't give a readout in the spot finder, you have to check the main display. Plus the display isn't illuminated as it is on the bigger Sekonics, which is really useful in low light.
