All models olympus m4/3 firmware update (faster AF)
^Definitely notice the improvement on the e-p1. Seems like the lens/camera doesn't rack in and out as much when focusing and now it just cuts to the chase and locks focus (with a hiccup every now and then of course). I only use the 20mm, but I'm curious as to how my e-p1 with the updated firmware stacks up against the GF1+20mm.
The Pen 1 & Pen 2 are much more accurate.
The speed increase is about what they said.
With the 17, you really feel the difference.
With the 20 , you feel it also.
With the Panny 14-45 it's very good also.
My manual lenses have no change at all. I need to grease the fingers more.
The big improvement I see is really in low light/contrast.
Much much better with all lenses.
So far I am not seeing low light improvement but I never saw it as much of a problem anyway.
With the 14-42 there is a little faster focus speed on the wide (not so noticeable) and much faster focus speeds on the long end.
As already said it seems to hunt less. There is a feeling when it finds the in focus point it is going past it only a little then returning to the point rather then the old feeling of it passing through the whole focus range.
All in all a successful update, but I still wish it could just go to the in focus point like my 5D rather than hunt around it.
Updating with the new updater was a breeze on my E-P1.
And indeed......it focusses faster and more positive with my 17 MM and 14-42 MM. Less hunting, even in low light conditions. Thanks Olympus for not forgetting the first generation Pen users.
Wow - My E-P2 LCD doesn't have the extreme noise in low light anymore. Let's say it's a lot better - less streaking in low light. I love Olympus - the first 35mm camera I owned was an OM1 back in 1976. After going Canon then Nikon through the years, I'm back...
BTW does anyone know where I can get a Nikon RF S to m4/3 adapter. I have a collection of old Nikon RF lenses.
Yeah downloaded the new firmware on my e-p1 last night... My only lens is the 17mm pancake and it does indeed focus quite a bit faster and more definitively. It's actually pretty scary how low light it will focus in.
Alls well!
I'm having trouble with the update. I installed the update software and followed the instructions but it is just staying on the "updating the firmware... do not disconnect.." Nothing on the screen of the camera like it says should be happening on the olympus website. Anyone got any suggestions?
its normal..i waited for 40minutes till the image on the camera lcd appear for next step..just be patience 🙂
I also had trouble, first time I've had issues updating Oly firmware. Typically it hasn't taken more than a few minutes per item to update. But today I got constant error messages, either "can't locate camera" or "can't locate server." This was after the software found both the body and the server enough to know which model body was connected and which updates were available for it. How it could figure that out but not allow updating baffled me.
Tried both Master 2 and Digital Camera Updater, 5 or 6 times each, same result. Thinking it might be related to Oly's servers being busy, I waited till later in the day and it finally worked.
So I stopped being a fan of online updating today, and wish Oly would go to a card-based firmware update scheme, like most others do.
Haven't had any time to play much post-update, but E-P1 w/17-2.8 AF does seem a bit faster.....
I got "can't locate camera" too, if you disconnect then re connect & press the OK button when the top option on the screen appears it seemed to work fine. Ran the updates for the E-P2 and Panasonic 20mm - big improvement in AF speed. Excellent to have the immediate capture appear on the LCD rather than the EVF too.
Ian.
The update went fine on my E-P2 too. I heard something about being able to get the menu up on the LCD while viewing the image in the EVF. Anyone know how to do this?
. . . David
No problems with my upgraded E-P1. My two Lumix lenses focus slightly faster. Hope this is all the preparation required for the M.Zuiko 14-150mm ED about to be released...
