When there is a failure of something mechanical, one of the things that is done is to decontruct the offending item, in this case the blowout preventer which was supposed to seal off the well incase of a castrophy.
So far I have not heard or read anything about detirmining why this device did not work and it is the main safety measure on all the wells.
I heard from a neighbor a person called into a late evening radio talk show
and he stated the reason for the failure was the the blowout preventer is powered by a battery. This preventer was not new, ie used before, and someone detirmined it was too expensive to replace the battery.
So let`s see they saved perhaps as much as $10,000 on a battery, but now are spending hundreds of millions on cleanup plus all the uncorrectable damage to the environment. Experts are saying there is simply no way to access the damaged wetlands for a cleanup.
The same oil company was involved in not inspecting the Alaska pipeline from the inside with a "car" because of cost. Another spill resulted there too from seam failures.
Perhaps instead of limiting the amount that they can be forced to spend on clean up, $75,000,000 by law, we need 100% responsibility plus fines equal to triple damages. But since big oil has bought off the politicians, we ain`t gonna see this. Don`t you feel good about out government watching out for us, both partys, I am not prejudiced. It is rempant.
What we can do is boycott the oli company responsible.
