700 euros - what M mount lens to buy?
tanel
2:12 AM
Estonia
I bought a M6 recently. Due the difficulties of selling my other gear I did not have money to get a M mount lens.
A job opportunity appeared and it seems I'll be documenting the behind the scenes for a shot movie.
These two just match together so well that it would be a sin not to take M6 along on that job.
So, due the difficulties I still have selling some of my gear to get an M mount lens, I have a spare of 700 euros (that should be around 875 US). What lens to get?
In theory I was going to get some 35mm Leica lens. Sadly I don't have time to raise my funds in such a short time period.
What would you do? Save and get the lens you wanted in a first place or settle for something less and re-selling it later?
Best wishes,
Tanel
(if this is in a wrong sub-forum I'm terribly sorry)
35mm Nokton f/1.2 would be a great option, nice and versatile. If you can swing the weight (which really isn't all that bad to begin with), then it's a stellar lens to work with. Not sure what the going rates are for classic 35mm summiluxes but you could take a look at those as well.
I'd go for a 35mm lens anyway. Very versatile focal range, depending on how you use it, it can feel wide, or normal.. that or a 28mm.. 50's can be a bit cramped, but if you think you got the space around you, then it might work as well. Something wide would be nicer though if you plan on shooting sets..
It is not said that Leica lenses are the best for everything, the first thing is to decide the FL, then if you mainly want to shoot colour or B&W, and finally, what ergonomics counts for you. I would wholeheartedly recommend one of the 50mm lenses, which are not that expensive, beginning with the Collapsible Summicron, Rigid or DR Summicron, or one of the later Summicrons. Another option which is greatly enjoyed by many, is the Elmar M - very much loved and very sharp, collapsible, hence light, but only f 2.8, or the Zeiss Planar, razor sharp
. In 35mm you could probably find easily one of the older Summicrons, or you could get the 35/2 Biogon, which is actually on par with the latest Summicron for half the price. Another interesting option are the CV lenses, which are sometimes not only great value for money, but actually great lenses on their own, like the 35/1.2 Nokton, that has the bulk as the only substantial drawback. So, choose the FL, and go to the classifieds to see what you can find.
50/2 Collapsible Summicron
Nokton 35/1.2
i would have bougth a summicron, 35 or 50 mm depending on what focal length you like the most
If you're heart is set on a 35mm Leica lens, you could get a very nice Summaron 2.8 for your money and come away with some change for film.
John
Sounds like you need a fast lens.
Decide on either 50 or 35, then I recommend one of: clean 50/1.4 Canon LTM, a CV Nokton 50/1.5, or a CV Nokton 35/1.4.
All outstanding fast lenses, that cost less than your budget. It does sound like spending less than 700 Euro will be welcome. 🙂
I recommend against the 35/1.2, due to size and viewfinder obstruction. Not exactly what Leicas were made for, IMO.
Roland.
I'm a wide-angle person, so anything longer than 35 would be pretty much no-go. My main lens is 24mm (on a canon's F-1 slr). While I do love such wide angle, it often is a bit too wide. 50mm is a bit too narrow, so I figure that 35mm would be perfect. And 28mm framelines on M6 is a bit hard to see for my eyes.
Although there is a 28mm Zeiss Biogon with uv filter and a hood for sale here just a tiny bit less than 700 euros.
As for film preference- mostly b6w but there are times then I find myself using color film (not as often maybe, but it happens).
If you are shooting indoors I would not dream of using a lens slower than f1.4 if you do not intend to shoot flash. Shallow DOF will also assist in portraits/people shot separation. IMHO forget Summarons and Summarits as they are too slow (as lovely as they area) and see if you can get a good used copy of the 35 1.2 Nokton. It will be very kind to the ladies too. I don't see too many other options apart from the 35 1.4 Nokton, which albeit smaller, seems to test not nearly as well due to focus shift and the like. Good copies of the admittedly huge 35 1.2 test very well indeed. I dont own one but I would buy one for the job you are referring to.
For the kind of work that you're intending to do, it sounds like the 35/1.2 Nokton is a good option. If you've never shot a really fast wide lens, that's the way to go. It will be a revelation, especially on an M.
Zeiss 35/2 Biogon is another option. Lower speed but very high contrast and a ton of detail. Less of a glow, more modern, raw documentary feel. I just bought the smaller 35/2.8 Biogon, but for what you intend to do I don't think you'll want a 2.8 lens. There are several good reviews of the Biogon f/2, here and elsewhere on the net.
Try to find the Voigtlander 25mm skopar for around 200 euros used. And then get a 500 euros summicron!
Why not a 35/2.5 color skopar? It's dirty cheap, if you go for the ltm version
(including adapter) and I'm sure you will be happy. If necessary, you can push
film, loose shadow detail and get strong contrast images behind the scenes...
If you prefer, the m version is identical. Also, the 40/1.4 is cheap and excellent.
Just don't try to get to much in the frame. Both much smaller than the 35/1.2,
and cheaper, and both will do the job (with the right film, with enough light)
Best,
Pau
Best wishes,
Tanel
a CV or zeiss 35 I guess
you can even buy a 35 and 50mm CV with 700€
If you are going to shoot low light (movie set, stage etc) - only sensible lens is the 35f1.2. It is a substantial lens - but unique in its speed and performance. It is also remarkably flare resistant - important for movie/stage.
The Summilux 35f1.4 non-asph is (and was) a very good lens in its time - but today lenses like the 35f1.2, Nokton 35f1.4 and the Nokton 40f1.4 are better - at considerably lower cost.
Anything f2 or slower will hinder you - you will keep running out of shutterspeeds that can be hand held. Also get a form of Soft release as that will give you a 1 stop advantage too.
The Zeiss 35f2 is very, very good - but it is a f2. The CV 35f1.2 is not that much bigger - and you gain 1.5 stops.
With a asa 1600 speed film and a f1.2 - your limit is probably more "to see what you focus on" than lens performance. You are down to light levels where the camera/lens sees more than you do!
Hey, I was in the same situation as you are now a few months ago.
I bought my M6 then had to make the same hard decision.
The 35mm choice was quite obvious for me, as I am a 35 kind of guy 😀
I made my choice on a 35/2 Zeiss Biogon. I had a nice second hand piece, for around 500€. I must say I am not disappointed. It is a really nice piece of glass. Its only disadvantage is that it is limited to f2. I come from a 35/1.4 Leica R. So I admit sometimes I miss the 1.4 but, you can't have it all 🙂
If you really want a Leica lens, then if you give it some time, you might be able to find a 35 cron at around 750€, but it is getting harder and harder.
