Shutter Counts on Ebay
squash
8:58 AM
I just received my M8 from Ebay. The seller advertised that there were only 537 shutter actuations.
How can make sure that this is true?
Ask to see all 537 photos taken with the camera...
Or you can have Leica service confirm this for you...(I'm guessing they provide this...)
I know that Nikon service has a program to do this...
Someone will have the correct answer for ya if you don't like this one...😀
Do you really want to know? What if it has 837, or 1028, but turns out in the long run to be a more trouble-free sample than another one that only had 437?
With my Pentax dSLR, the camera writes the true shutter count deep into the exif data of each image file. Using a free software called PHOTOME I can read this value. It might be worth trying this to see if the M8 also writes this value to files.
Take a jpeg, look at the EXIF data (I use EXIF Viewer on the Mac) there is a hexadecimal number in the EXIF, convert it to decimal (there are some web-based hex converters.)
Soooo.... which hex number? I see many! I had this issue with another viewer, I mean what the date and time value? Color space value? What am I missing here because EXIF Viewer does not display 'UniqueImageID'...
And you know I'm beginning to think like Rob F said - does this really matter in the end?
See where it says 'Unique Image ID'?
Take the last digits and convert from hex to decimal.
This is using EXIF Viewer.
I see it in your dump, but not mine. Not wishing to complicate matters (this is really more an exercise for me...) but the that line of data does not appear when opening image files on any exif viewer I use. Maybe the info is stripped out from iPhoto (it's all I have on the road to manage images with at the moment...). Hmmmm very interesting...
actually
actually
according to other m8 owners, Leica cannot confirm this data. The exif data collected is also unique images written to card, not shutter actuations, and not permanent metadata.
Of course it is good to know, it is camera mileage, my M8 for ex has more than 85k on shutter.:bang:
