Worse than a Visoflex?
1ScrewLoose
2:11 AM
Is there any reason one could not use an old PLOOT (pre-visoflex mirror reflex housing) on an LTM Bessa body -- on, say, a Bessa L?
I recognize such a setup would probably be maddeningly clumsy...
Thanks, Roger! I'd be using it with older lenses (e.g. 20cm f4.5) so the thickness would not be a problem. It's a "special project" situation where, if I understand the setup correctly, the 30x magnification of the POOIM finder might offset the other hassles involved.
I _do_ love the 65mm on a "real" visoflex on the Bessa T, or ZM.
