G1 + super Takumar 50f1.4
blacvios
1:39 PM
Great combo, pics speak for themselves.
B & W
Color
I remember an article in which a radioactive lens was tested with a Geiger counter ("violin counter" in German 😛) and it turned out that the radioactivity was not higher than the general radioactivity of the room, that means, lower than the photographer's body...
I would use mine on the G1 were it not for the radioactivity. Maybe it wouldn't mess up the sensor, but why chance it? I've got other f1.4 normals. Great shots though!
There is no problem with this lens and radioactivity, the only thing is the isotope as it ages can give the lens a distinct yellow cast. Apparently this can be removed by leaving the lens in bright sunlight for a few weeks. The UV does the trick
Chris
Yes both of my 50mm f1.4 Takumars (Super Takumar and Super Multi Coated Takumar) are discolored dark yellow brown. I need to give them the UV treatment someday. I've read about the thorium glass used in these lenses, and the readings are more than just background radiation. It's really off the charts for this lens, the Industar-61 I own and as I understand it, the Pancolar lens is very high also. I don't own that one. Maybe it's nothing to worry about, but who really knows?
The 50mm f1.4 Super Takumar / SMC Takumar is renowned amongst those who know it as a superbly sharp lens with even more superb bokeh. It is an absolute beauty of a lens. And it is cheap to buy (although a little less so now that its attributes are known more widely.)
