Question about Voigtlander 40mm Viewfinder
Adam14
6:34 PM
Because I wear glasses,I have trouble seeing the entire 40mm framelines on my Bessa R3A with the Nokton 40mm f/1.4. Would the Voigtlander 40mm Brightline Viewfinder solve this problem? Anyone have any experience with this device?
Thank you
Yes, usability for eyeglass wearers is very good. Also very bright image. Be aware that the 40mm VC finder is optimised for Leica M bodies in the sense that the finder is a tiny bit offset with regards to the hotshoe mount. This in order to reduce lateral parallax error on Leica M bodies, as the lens axis and the hotshoe are not laterally aligned on M bodies.
