Canon 50 1.2 LTM for a Bessa R3
Gallo
3:07 AM
Hi, everybody. I got the chance to buy a Canon 50mm f1.2 LTM lens, the seller is asking $600 (the lens is in good condition, but not mint) with the LTM to M adapter included. Would you buy it to use it in a Bessa R3 or should I go for a Nokton (50 or 40 1.4)?
Thanks!!
Santiago
Hmm. While the effective rangefinder baseline of the R3 isn't as short as the R2 and R4, at 37mm it's still pretty dinky. The effective rangefinder baseline of the Canon 7 and 7s are a healthier 47.2mm.
I'd be concerned about getting very random focus with the 50/1.2 on the R3. I find it enough of a challenge on the 7s.
Santiago,
There is right now a Canon SLR 55/1.2 FL lens that was custom changed to M mount being offered for below $400 here. The 55/1.2L is a better lens that the 50/1.2 RF lens.
My recommendation is to save over $200 and get the 55/1.2.
raid,
nanthor has pulled the 55/1.2 since it apparently backfocusses on his M8.
@OP: if you want to try and shoot that 50/1.2 I'd get it and see if it works out. If not, you can always sell on. Price is a bit steep though, I'd go for USD 550.
You might like it so much that a Canon 7 or 7S or an M3 will follow later. These bodies are much less straining when it comes to focusing. OTOH, Tommy Oshima uses a Noctilux on a Hexar RF, which has a .58 magnification!
While the Hexar RF has 0.58 magnification, it has a much longer physical base line, for an effective rangefinder baseline of 41.10mm. But, hey, that's not a lot longer than the 37mm EBL of the R3.
Thanks for the advices, guys! Raid, I will check that 55 1.2, sounds tempting.
I mentioned the Bessa R3 `cause is the camera I would buy in a near future, but don`t have it yet. Maybe the 50 1.2 LTM couples better in another Bessa? Which one?
Thanks agian!!
I had thought to agree that $600 was a bit steep, but just checked KEH - $725 for EX and $525 for BGN. Prices are way up again.
I think it's a fine lens, and most of them are surprisingly good wide open in my experience. It is very sharp stopped down a bit. It will probably go up in value - that's certainly the trend. I think $600 is a bit high, but not excessive. The main thing is to make sure the glass has no issues like haze, fungus, oil or serious scratches.
Wow, when I paid $200+ for mine five years ago I thought it was on the high end. Good thing I've decided to keep it.
I have seen the 'bay with some of these in the $600 range. Again, what the Market dictates...
To be fair, it was a bargain at $350, and still a pretty fair deal at $500-600 as far as fast 50mm LTM primes go. Next cheapest is the 50mm f/1.1 Nokton if I'm not mistaken.
Thanks again for the input, guys. I live in Argentina, and those lenses are far from common down here. I asked the seller for pictures and noted a small, but noticeably, hit on the filter ring. So, the lens is not in MINT condition. I think I would go for a fast 40 (such CV 1.4) or a fast 35.
At $600 for a Canon 50/1.2, I would go the extra amount for a 50/1.1 Nokton. Much sharper wide-open.
Make sure to inspect the Canon: the surface behind the aperture blades is prone is haze and etching.
I bought a Canon 50/1.2 recently. I'm fully aware of the twin-character of the lens: opened up it's a softish bokeh monster and stopped down it'll become a normal classic low contrast RF-lens.
I like it that way. I like the Canon 50/1.2 lens more than my Summilux 50mm/1.4 Pre-ASPH.
What is a problem is the hood which is d****d difficult to find and very costly. Maybe Tom A. could make a nice replacement hood for Canon 50/1.2?
Here's one at f:1.4:
I've got a black/chrome Canon 50/1.8 with a repaired filter ring ding. But the aperture ring was also tight because the front lens block was "reshaped" by the incident. A little filing has solved that bind, but I suspect that the lens's optical quality is going to be "off". Haven't run a test roll, expectations not high.
Thanks again, guys, I think i`ll pass on the Canon. A friend of mine is going to Chicago soon, maybe it`s time for a bessa and a 40 1.4 😀...
