. . . And while we are asking questions . . .
. . . Why the 1:1 finder? With the 1.5:1 crop factor, I would want to use the finder with wider lenses, such as the 24mm and 21mm. Eyeglass wearers tell us they can't even see the 28mm framelines with the 1:1 finder. I'd have bought an R-D1 a long time ago, if it had a lower magnification and frames for the wider lenses. You need to be able to use a 24mm lens just to get the equivalent of the tried-and-true 35mm field of view. The R-D1 should have a .7 finder and 21 and 24mm framelines. Well, Ok, the R-D2 should have that option for those who require it. The R-D1 is for those who like the normal and longer lenses.
