1938 leica II - a question
greyelm
Malcolm
8:54 PM
London, UK
Just a question to answer my curiosity
I have recently obtained a 1938 Leica II s/n 2946xx and notice that the rewind clutch lever has an extra piece of metal which engages with the top cover when set to A. My IIIA, IIf & IIIf do not have this extra piece of metal, is this a design feature of all model II's or is it just this year? Also the speed dial has 20-1 on it which I thought was meant for those with a slow speed dial on the front, it could be a replacement or was it the 'standard' dial used in 1938?
The speed dial's "20-1" or vice versa appears on all mine of that vintage (give or take a year or two) with and without slow speed dials.
Can't comment on the lever, sorry.
Regards, David
The knob looks like a IIIa one, and the lever could be too - I have seen this use of available parts before on the II / III range. With a '38 II it should be OK with the smaller diameter IIIa knob - the earlier II bodies (1932/33) had the larger dia knob, and it does make a slight difference to shutter speed if you fit the wrong one.
At least it has "Z", not "B", which would indicate a much later knob.......
Mine is from 1934, and does not have the same kind of rewind lever. Mine has the more usual kind. In fact, yours is the first I have seen of that shape lever. Mine does, however, have the 20-1 designation. I looked in Jim Lager's book, but did not see a lever of that type. I imagine it is fairly rare.
