tlitody
Diffraction is always present. It is caused by the aperture edges which cause light to bend as it passes by them. Aperture diffraction increases as lens is stopped down. There is a point where it becomes more significant than other lens apertures.
But there are always other aberations in a lens too. So optimum aperture is a compromise between difffraction caused by aperture and other abberations. In 35mm format it is usally around f5.6 to f8. There are lenses for 35mm which perform best at wider apertures and some that perform best at smaller apertures. Each lens has a sweet spot where the minimum total abberationstake place(not the same as minimum diffraction which is always wide open). It is worth testing for this which is quite easy to do. Just make the same image at different apertures. You can actually see the difference. If using wet printing then do the same in the darkroom with your enlarger lens. i.e. print each image at the same aperture and pick the one which is sharpest (not DOF but sharpest in center). Then you know your camera lens sharpest aperture. Then take negative and print it at each enlarging lens aperture and pick the sharpest result. You will then know enlarging lens sharpest aperture.
When you combine your camera lens sharpest aperture with your enlarger lens sharpest aperture the difference is very obvious. Most people never bother to do this and wonder why their images are never as sharp as they think they should be. But you are then limited to dof obtained by camera lens sharpest aperture but you can always use enalrger lens sharpest aperture so its worth doing the test and can choose when to use camera lens sharpest aperture over using max or min dof.
Note: Large format lenses tend to have more of other abberations because of bigger elements. And LF lenses cannot reach the resolution of smaller lenses for 35mm cameras but then you don't the need the same enlargement so you can obtain a higher print resolution for the same size print with LF because of reduced enlargement factor. Again a LF lens will have a sweet spot you should test for sharpness so you know where it is and can choose when tou use it over dof.
