significant diff between 17 and 20mm?
FrankS
Registered User
12:00 PM
Canada, eh.
I have a couple of Nikkor 20mm lenses but am thinking about a 17mm lens for my Canon EF body. Is there is big diff in field of view? How much would you pay for a 17mm FD lens in great condition?
To me it seems like a fairly significant difference. I went from a CV 21/f4 on the rangefinders to a Tamron 17/f3.5 on the Nikon, and it looked and felt a lot wider, without becoming as extreme as a 15 would have been.
In Germany a Canon FD 17/f4 would usually sell for something between 120 and 200 EUR depending on what the lens looks like. I don't know what prices are like across the pond, though.
Thank you Dr.
The other possibility is an FD 24mm for $90. That way I don't have too much invested in a "side" SLR brand for me. (I'm mainly Nikon and then OM.)
I believe that Raid has a Canon 17 that he also uses on a RF camera with an adaptor. Scale focusing a 17mm lens is no hardship!
Well, FD isn't too bad as "side brands" go, seeing that the stuff is still relatively cheap, but it's still money...
Your situation is exactly why I bought a Tamron SP 17/f3.5. It has an Adaptall mount, so you can change it relatively easily between cameras. I think I paid around 100 EUR for mine; it came with a FD mount, so I had to get an Adaptall mount for Nikon, too, but now I can use it on both. I think it's one of the most useful Adaptall lenses. Optically it's OK, some funny distortion towards the corners but then it's a 1980s superwideangle. The built-in filters are nice.
Definitely - that shouldn't be a problem at all.
I have a limited amount of $ in my photo gear war-chest, so I decided to go with a $55 Canon 24f2.8 with a trace of fungus on an element. That leaves me enough left over for some CLA work on a few cameras I have that need it. (shutter capping and a weak beam-splitter on my 2 IIf's)
The 17 was tempting but it would have depleted my funds too much.
Good decision. The Canon 24 is a very good lens.
If you want to use it on another system at some point, according to a tip I recently read in a German newsgroup it also makes a very good extreme macro lens in the large scale range (5:1 or so off the top of my head). Just put it on a bellows with a 52mm reversing ring. 😉
You've already got the 24mm, but you might want to keep an eye out for that Canon 17mm lens. It gives you a perspective that is significantly different from either a 24mm or 20mm. I got mine, a newer FD (bayonet) copy, at an estate sale for $150. After that, I got an F-1 body for $50, just to be able to use it. At first, I was going to mount it onto a Bessa L, but I had no external viewfinder that was even close to suitable for that wide a lens, plus it felt so huge on the Bessa.
