discrepancies in image size
chris91387
12:20 PM
Southern California
i hope this is the right forum.
anyone else notice a discrepancy between the stated image size between their computer and what RFF says it is upon uploading? see attached two screen grabs for the same exact file.
-cs
Ha! Funny you should say that. There actually IS a standard. It's a matter of who's standard you believe in.
HDD manufacturers like to use base 10 math, so a gigabyte is calculated as 1,000,000,000 bytes. The confusion arises because computers have always used binary, or base 2 math. That same gigabyte is then calculated as 1,073,741,824 bytes. Add to that the fact that formatting a drive consumes additional space. In the end, that "500GB drive" only gives you 400-and-change GB. Apple even got sued over this nonsense.
More details on this...
http://blog.tweefari.com/apple-mac-os-x-106-snow-leopard-uses-base-10
http://support.apple.com/kb/ts2419
Though it seems this changed in SNOW Leopard (10.6.x) whereas you're running the previous, regular Leopard (10.5.x). Perhaps it changed in a subsequent update to make the two behave similarly...
you're making this stuff up, right?
