What's the story with this M2?
mto'brien
3:45 AM
I've seen this M2 being offered for at least a month now and I assume so have some of you. The seller keeps dropping the price every time they put it up for auction, yet no interest. It is now in user price territory and the seller claims it is an impossible to find Leica M2 rarity. I'm not buying it either.
So, what is with the story in the description? Fake? Top plate from a different body? Real Leica mistake?
http://cgi.ebay.com/LEICA-MIS-PRINT...505682030?pt=Film_Cameras&hash=item230ad6746e
I've seen the ad and it is hard to make sense of what he is claiming. He seems confused about the difference between an M1 and M2 and about the whole thing with the serial number.
It is probably a M1 that has had the M2 rangefinder installed. The picture is a bit fuzzy of the top-plate -but it does look like there is no prefix "M2" before the number. It was a fairly common conversion ( I have had a couple done). The M1 is pretty useless as it is and in "the good old days" it was an easy (and cheap conversion). The lever rewind is another simple conversion.
Many years ago I had an old and battered Army green M1 converted - it became an old and battered green M2 instead.
funny, the auction had about 20 views an hour ago... now it's over 100. if it sells because of this thread, the seller owes me a tortilla.
Leica was known to undertake various conversions back in "the day". I own a 111a with a 1936 serial number (in very fine condition incidentally) that was at some stage updated with the Leica 111f flash sync, complete with the 111f shutter release collar containing a dial to set time for the flash to go off. (Different flash bulbs take different times to reach maximum brightness and had different burn times so they needed to be set off at slightly different times to give a predictabel result. This collar made fine adjustments of that nature.) Also the lens a 1936 50mm Elmar was also updated with the addition of coating, presumambly at the same time. This was a particualrly nice and not all that uncommon conversion.
interesting, thanks Peter.
I wonder what other conversions leica was known to do?
these would be useful things to know while camera shopping. oh who am I kidding, I'm pretty much always camera shopping.
Anything that was technically possible: even the ones that weren't advertised were often done, much like 'a la carte'. 'Upgrades' on the same basic chassis were quite common. When I saw it, for example, #139 was a ratty II with a horrible (non-Leica) synch added. Remember that was the 9th Leica ever made...
The problem is there's no way to verify the origin of this camera.
I doubt it's a Leica mistake as the seller claims.
More likely a repair done on the cheap. Maybe the camera was dropped and the top plate was swapped with one lying around in a techs work area.
At the asking price it's not a bad deal but what else has been "cheaped" out? 😕
