dyao
I've downloaded the J-86 datasheet which is rather unhelpful. There are no instructions on the box/bottle other than how to mix it, and even that is confusing. How do you make the stock solution, and then how much do you dilute that to get the working solution?
I've found some info on other sites where people add the solution B to solution A, and then dilute that 1:9 for working solution. Other people recommend diluting solution A, diluting solution B, and then adding solution B to solution A after developing.
Would appreciate it if somebody could explain this to me as if I'm a 5 year old. Thanks!
