zorki 4 eyecup
atar
12:19 PM
Italy
Hi all,
do you know if exists an eyecup for zorki 4? I wear eyeglass and Zorki is a terrific eyeglass killer. How can i solve my problem?
You can purchase aftermarket kits that come with a variety of mounting options, the rubber eyecup slides onto each different mount. None of the mounting blocks would suit a zorki as they are but i am sure you would be able to adapt one to suit. I have a set here and in the time it has taken to write this i have stuck a mounting block onto mine with double sided tape.[ i used tape designed to hold auto trim on the side of a car]
regards
CW
You could also fix three good drops of hot glue around the viewfinder, so that your glasses contact the glue drops instead of the metal. Not very academic but it works for me.
I killed a pair of very expensive glasses before I discovered this solution.
