Stand Development & Tank Size
SixFlags
2:50 AM
Germany
After sawing this thread on flickr I want to try out a 1:100 Rodinal stand development of pushed Tri-X too.
Though in the first post he wrote that he used a 500ml tank.
With a 300ml tank though, there would be only 3ml of Rodinal in that dilution. I've been wondering if the developer will exhaust before the developing time is over.
Not to highjack the thread... But I have Q or 2 about Stand Development...
1) Why?
2) How do I figure out the time?
I shoot Fuji Neopan 400 at 320, I use Rodinal 1:50 now. (6ml for 300ml)
1) Why?
1. It is cool, rather easy and you can get some very smooth tones without blowin the hilights
2. Just look around on here and google. Maybe start with 1:100 for 1 hr with 400asa film and go from there. It is hard to really screw it up 🙂
Is 1 hour just a generic time.. Temp doesn't matter?
I'll try it on my next roll....
Is there a certain type of lighting or subject matter it works better with?
Or, it works fine with all types of lighting/subject?
Yes, it will. Stand-development is based on developer exhaustion. Concentration, i.e. 1:100 or whatever doesn't matter. 2h or 4h doesn't matter either. For nominal film speed, and 35mm, use 3ml per roll. 3ml just happens to be 1:100 for the typical 300ml water a development tank takes per roll.
You can also exhaust with what's called "semi-stand". These days I use 30', with 1 inversion every 3 minutes. Gives me more even results, with the benefit on grain that stand provides.
Roland.
WOW, My 1st roll of "Stand" development looks VERY GOOD!
I took a sample of photos where some where mostly highlight tones, some where mainly darker tones. I metered as usual, and it likes the highlights are not blown, and the darker tones are just WOW...
Can't wait to scan a few !!
DNG, how did you meter a typical sunny scene? I've read that exposing for highlights is ideal, but I did a few shots with a typical 1 stop over expose during a sunny 16 scene and those negatives came out briliant! The one where I exposed for the highlights were a bit flat for me. Perhaps I just metered wrong or something. How about you? Cheers!
I just metered as normal... centered what I wanted right, and locked it, and recomposed... Worked most of the time... Since the Contax G1 does not have a spot meter, I lower my ISO to overexpose, 400 @ 320 is OK, but, I think 250 will be better for using Rodinal 1:100 Stand.. For Rodinal 1:50, regular develop workflow, I can use 320 or 400 with good highlight results. But, Fuji Neopan 400 is more a 320/250 with Rodinal anyway, I am finding out, with around 15% less time also.... I guess if I want to push FN400 to 800/1600 I'll have push to 640/1250 instead with 15% less time.
EDIT:
I don't mind a little flat, I scan, so that can be fixed during my scan or in post.
Does "Stand Developing" work with other developers?
Which ones?
I have been asked this Q on anther forum I help Moderate.
Some people have experimented with HC-110 but results have been inconsistent AFAIK.
Stand developing with Rodinal you sometimes get nasty base fog. Adding 1gr of Borax to the solution helps with that.
Which ones?
I tried it once with XTOL 1:3. Stand for 1 hour. I definitely got images. This was with TMZ, and I never messed around with it again to figure out what I should rate the film at, but it was somewhere around 3200. It scanned alright, better than the shot at 3200 but developed normally at 3200. However, I have no idea how it would wet print. I've been meaning to return to these tests but haven't had the time to do the darkroom half of it, which is important to me.
You are mostly doing stand with scenes of many different/many Zones: E.I. 8-10 Zones. That is why you are suppressing the highlights. Pushing isn't one of the reasons for stand, but people do it for everything now.
Also, Ansel Adams did a variation of stand using HC-110 (1:120). I have done it many times and it is great with TriX and probably any old emulsion. Usually, people on the Internet have said that the Tmax and Delta, etc. emulsions don't work well with stand, but I have not had a problem.
Personally, I like HC-110 better than Rodinal because of the fog and streaking tendency. But I have had good results sometimes with Rodinal:
My second roll is in the soup now, I think with Fuji Neopan 400 at 250 will work for me. I understand Pushing is out, but, Pulling seams to work, and keeps the highlights better. I am trying 1 agitation at the 30m mark for 30s, and see how goes.
I like the old fashioned films over the T/tech films, Yes, a bit more grain, but very pleasant tonal scale.
Beautiful photo, and rich highlights
Was this done in HC 110? What ratio, what film, how long? Cheers!
