Supports a wide variety of industry-standard film(negative and positive) sizes -
including 35mm, 120/200mm, 6 x 4.5cm, 6 x 6cm, 6 x 7cm, 6 x 9cm – 6 x12cm
Superior quality, 3-line CCD sensor
48-bit, 3200dpi optical resolution
Industry-leading scanning speeds
Automatic dust & scratch removal
With the new PrimeFilm 120, we have built the same functionality and quality you have come to expect from our dedicated 35mm film and negative scanners, and extended it to include a wide variety of professional film formats. It also includes Magic Touch, our unique and patented technology for automatically removing dust and scratch damage from films. An advanced 3-line CCD sensor and fast scanning speeds - even at gorgeous 3200dpi optical resolution - round out the package and make this model really stand out as the obvious choice for scanning a broad range of film sizes.
Scanning Media
Media: Negative and positives, in color and monochrome.
35mm film: 1 strip of 1-6 frames (max.)
35mm slides: 1- 4 slides with mounts.
Medium-format film: 1-2 frames (6 x 4.5),1-2 frames (6 x 6),
1 frame (6 x 7, 6 x 8, 6 x 9, 6 x 12 )
Optical resolution Up to 3,200 pixels per inch.
Image Sensor 3 line R, G & B linear CCD sensor
Color separation Performed by CCD RGB filters & white LEDs
A/D conversion 16 Bits per color
Optical density Over 3.6 Dmax
Output Full color or gray scale at 8 or 16 bits per channel
Interface USB 2.0 ONLY (USB 1.1 not supported)
Light Source White and Infrared (IR) LEDs
Power AC 100-240V, 50/60Hz
Dimensions 160 mm (6.3"H) x 200 mm (7.9"W) x 400 mm (15.7"L)
Weight 5.6 Kg (12.3 Lbs)
PC
Operating System 32 & 64 bit Windows XP/Vista/Win 7, USB 2.0
CPU Intel P4 2 GHz or higher or AMD 2.0 GHz or higher
RAM 1 GB minimum
Hard Disk free space 10GB or greater
DVD-Rom drive (DVD-R drive required to make DVD image archive disks & CD-R drive to make slide shows) Will we be bundling Adobe elements if not then this can be removed
MAC
Operating System MAC OS 10.5+ INTEL based processor, PowerPC NOT SUPPORTED
CPU Intel Core 2 Duo, speed 1.8 GHz
Memory/RAM 1 GB, 667 MHz, DDR2 SDRAM
Package Contents
PrimeFilm 120 Scanner
• printed user manual
• USB 2.0 cable
• A/C adaptor
• scanner driver CD - Cyberview X, Adobe PhotoShop Elements 8.0
• media holders: slide holder for 4 framed slides up to 3.2 mm thickness, film holder for film strips with
up to 6 frames, 1 medium format holder for 1-2 frames
(6 x 4.5 cm), 1-2 frames (6 x 6 cm), 1 frame (6 x 7 cm, 6 x 8 cm, 6 x 9 cm, 6 x 12 cm)
