NormanV
What is the difference between an Industar 50 and an Industar 22? They are both 50mm f3.5 lenses.
On a side note: why would anyone use the non-collapsible I-50? I don't mind the f3.5 limitation of my I-22 because it's collapsible, but if you're using a fixed lens, even the I-26 at f2.8 would be preferable, surely?The I-50 was mostly made in rigid mounts, which are possibly not as convenient as the collapsibles.
because a lot of them are based on non-standard flange-to-film distances
It doesn't even look good (IMHO).
Well one reason would be that many cameras were supplied with the rigid lens and it hardly seems worth buying another for an extra 1/2 stop, particularly as there is the risk that another lens might need shimming to focus correctly. Some users might find the rigid lens more reliable since there is the chance that the collapsible lens might accidentally not be pulled out and locked properly sometimes.
Lenses and camera's where standardized in the post war production range. Shimming is neccesary when someone has lost a few shimms when the camera or lens was disassambled for lubrication. That's often.
So far I repaired and CLA'd dozens of FSU camera's. I read many compliants about quality controll problems. I seldom open a camera which hasn't been serviced or opened before in an attempt to self repair.
I got a Zorki 2C yesterday over the mail. Its working distance measured out 28.5mm instead of 28.8mm. You can see the screws have been used before, and inside a screw is missing.
Isn't this something of a vicious circle? The cameras are worth next to nothing, so people have no compunction about going inside them to fix real or imagined problems. Half the time they get it right; the other half the time they make things worse, at which point the options are scrapping the camera (including cannibalizing it for parts) or sending it to someone such as yourself who knows they're doing.
Remember, too, the old saying: If it doesn't fit, do not force it. Get a bigger hammer.
je2a3, the rigid I-22 is on my "want list" and it looks pretty good to me as well. I particularly like the tab on it.
What size for filters/hoods? Rob
Thanks! Elmar 50/3.5 Fison hood fits perfectly, no filter thread so A36 clamp on. It came with that Zorki 3, ebay USA seller, a few years back...good luck hunting!
