tho60
Reading the English version of Zorki-4 manual, I have found a very interesting statement:"
It should be taken into consideration that any replacement of the standard camera lens calls for adjustment of the new lens to fit the camera. "In Fed-2 manual: "However, it must be taken into account that each change of the main lens is connected with the necessity of the subsequent adjustment of the lens to the camera."
How do you think about?🙂
Well, I started this thread because in practice, my Jupiter-9 is not interchangeable between my cameras. Mounting on most of my Zorkis, it gives rather acceptable than terrific results. Only one Zorki-1 camera can produce sharp close-ups wide open with it, and I found this camera and result by chance. (I have tried to shoot test pics with several cameras and I chose the best one.) However, my 50 mm lenses are interchangeable without any problem. So, I have bought an other Jupiter-9, suspecting that the former lens was defective, but the problem remained.😕
From about 2 meter distance, each of them works flawlessly, but taking close-ups is like a Russian roulette- sometimes succeeds, sometimes not.
I am eager for knowing your opinions and advices! 😉
