ferider
OK, Tried using 2ml for 300ml water... Not enough, Exhausted too soon,
Back to 3ml per 300ml of water
BUT, I will try 4ml to 400ml water next. just to see if it is better than 3ml/300ml.
Let me say this again: the quantity of water doesn't matter for stand, as long as you cover the film. Dilution is not the right metric, Rodinal quantity is. At nominal speed, use 3ml for one 35mm roll. For 2 rolls use 6, etc. To push one stop and one roll, use 4-5. If you use less (2ml) you are pulling.
