imax
Not too old to learn
I'm new to the world of rangefinders and Yaschicas, although not old film cameras, and am enjoying rediscovering the joys of manual cameras and black and white film. And I've enjoyed reading the posts and discussions in this forum.
I've acquired an Electro 35 GSN that needs some repairs. I've fixed the jammed self-timer lever (I think, but can't check it because of the problem I describe below) and freed up the shutter blades (isopropyl alcohol), but haven't got to the source of the lack of power to the camera.
But I'm stuck on the jammed film advance lever. It will only move a quarter turn before striking something solid and stopping. It does not cock the shutter.
However, if I press the shutter button, it engages the locking pin at the bottom of the camera, and winding the advance lever releases that pin and it pops back up, so I think that's possibly not part of the problem. I've looked carefully under and around the connections under the lever, but I'm loath to dismantle the mechanism because of all the springs in there. I've applied isopropyl, but from the feel of the obstruction (it's very solid) I don't think it's sticking because it's dirty.
The film take up spool moves a little, but does not turn as much as the lever (a quarter turn).
Or could it be something in the shutter mechanism you get access to by taking the lens off?
Has anyone struck this before, and do you know what might be causing it? I don't mind pulling the camera apart as I'm not attached to it and it cost very little.
Cheers
Iain
Cheers
Iain
