tlitody
Just wondering which are the slowest B+W films currently available ?
							I want to know this also + SIDE QUESTION, are modern slow ISO 100 films like TMAX100 sharper then old slower films like Efke 25?
There is a concurrent thread about shooting infrared where people are talking about Efke 820 with IR filtration having an effective e.i. of 1 or less. And it is said to have high reciprocity failure as well. So if an e.i. of one is still too high, stop down the lens and your exposure time becomes infinite.
The reason I asked this question is because I was thinking about fill flash on a Zeiss Ikon ....................
Now I understand. May I suggest an alternative of a 3'x4' sheet of white foamcore used as a bounce card? If you really want to get spiffy, spray one side with contact cement and stick on aluminum foil. That is how I deal with the problem.
The reason I asked this question is because I was thinking about fill flash on a Zeiss Ikon which has a max sync speed of 1/125 th.
On a bright sunny day you will be at or close to the sunny 16 rule. All well and good except if you want to shoot at F4 instead of F16 you can't close down 4 stops and chnage speed to 1/2000 because you lose sync speed. So if you want to use fill flash and F4, you would need a film speed of around ISO 8 just to get a shutter speed of 1/125 th with some fill flash.
Now I see why people like leaf shutters for fill flash work in bright sunlight.
I also have about 20 rolls (120) of Agfa 25 in my freezer, but now I'm just bragging.
Dear Bob,Now I understand. May I suggest an alternative of a 3'x4' sheet of white foamcore used as a bounce card? If you really want to get spiffy, spray one side with contact cement and stick on aluminum foil. That is how I deal with the problem.
