Cable tie focus tabs: Anyone use them?
  • Yes!
    Votes: 0 0.0%
  • No! I tried and it was rubbish!
    Votes: 4 8.2%
  • Never tried
    Votes: 45 91.8%
  • Total voters
    49
  • Poll closed .
Not on a rangefinder lens, but I have one on a 35mm prime lens on an SLR. As with the 35 Summicron, the finger tab gives me an index mark for prefocusing (tab at 6 o'clock = focused at 1.5m). It works ok, cheap and easy to remove if you don't like it. For wider lenses the DOF is usually so great you don't really need it, and for longer lenses it's not accurate enough. For 35 it's pretty useful.
That is a great idea. I must try it. I am a firm believer in the Steer by Leicagoodies but they are too big for smaller lenses.
alternative
alternative
i've never tried cable ties for focusing support, but can imagine they might help with specific lenses.
for larger lenses, i use the "steer" ring from leicagoodies. it's a comfortable, useful addition to lenses with stiff/long focusing rotation.
greetings from hamburg
rick
If you're worried about them slipping off, you can use one of these:
I've used a hose clamp similar to that up above, they work well if you want a tab. They won't slip either. Though the screw isn't the most comfortable thing to rest on your finger 🙂
Well, I've had it on for about a week and it does have a tendency to fall off when the camera is going in and out of bags. Usually it just slides toward the body and putting it on is quite easy. It's nice to have a tab but this is probably not the best long term solution...
Just buy a tabbed (early) Jupiter 8 then. 😀
